Worthing
Victorian and Edwardian terraces, seafront flats and post-war family homes each need a different approach to boiler size, flue routing and hot water. We will recommend a combi, system or regular boiler to suit the property.
Looking for a new boiler in Worthing? Our Gas Safe registered engineers supply and fit natural gas, LPG and electric boilers, with a free home visit and no-obligation estimate.
Along the coast from Littlehampton to Worthing and up onto the Downs at Findon, we look after boilers, central heating, gas fires and cookers for homeowners and landlords. Our engineers are Gas Safe registered for both natural gas and LPG.
A town at the mouth of the River Arun with plenty of bungalows and family homes. When a new boiler goes in, we check the rest of the system too, because older pipework and radiators often benefit from cleaning or upgrading.
A coastal village between Worthing and Littlehampton. For larger homes that need plenty of stored hot water, we are qualified to install and service unvented hot water cylinders (G3).
A Downland village inside the South Downs National Park, a few miles north of Worthing. Some rural homes here use LPG, and our Gas Safe registration covers LPG boilers, fires, cookers and pipework.
Like most of Sussex, the coastal strip has hard water. Limescale builds up inside a boiler’s heat exchanger, so protecting a new boiler pays off over its lifetime.
Water softeners →Rented homes and flats need a gas safety record every year. We carry out landlord gas safety checks and keep your records so the next one is never missed.
Landlord services →We are registered for gas fires, cookers, hobs and range cookers on natural gas and LPG, so one engineer can look after all of your gas appliances.
Fires & gas appliances →Our entry on the Gas Safe Register lists the work our engineers are qualified to carry out, on natural gas and LPG.
Yes. All four are part of our Worthing area, and the same team of Gas Safe registered engineers covers each of them.
Hard water leaves limescale inside the boiler and hot water pipes, which reduces efficiency and can shorten the boiler’s life. Scale protection and a water softener both help.
Yes. We carry out annual landlord gas safety checks for landlords and letting agents and can send you reminders when the next one is due.
Choosing a new boiler starts with a conversation. We'll visit your home, look at your present system and talk through how your household uses heating and hot water. With access to a range of makes, models and guarantee lengths, we'll recommend the boiler that fits your home and budget — and give you a clear estimate with no obligation.
Free
We regularly install and service boilers for homes and landlords in Worthing and the surrounding area, with extended Worcester guarantees available on eligible boilers.
Each type suits a different kind of home. We'll confirm the best option when we visit.
Heating and hot water on demand from one compact unit — ideal for smaller homes with little loft space.
Works with a hot-water cylinder for busy homes where several taps run at once. Solar compatible.
Conventional heat-only boilers with cylinder and loft tanks — great for low-pressure areas and older systems.
We assess your current system, your household's needs and your budget.
A no-obligation estimate with boiler and guarantee options.
Gas Safe engineers install, commission and explain your new system.
We keep your records and remind you when your service is due.
Book a no-obligation home visit and we'll recommend the right boiler for your home and budget.
